Bigger fuel lines with stock rails.
Can I run bigger fuel line while keeping sotck fuel rails and a 255 Racetronics in tank fuel pump.Can you just connect the bigger line to the same spots the stock line is connected?
No point in running bigger line you will just run into the next restriction IE the rails or the pump will not keep up with the volume to fill the new line. The stock line is almost -6 size and will flowover 600rwhp.
Nate
Nate
