Cannot find fitting
Old Jul 26, 2005 | 01:44 PM
SiL3NtXWS6's Avatar
Default Cannot find fitting
I have looked everywhere and cannot find a -4AN female to 1/4" npt female adapter fitting for my fuel pressure gauge. Does anyone have a source for this piece?
Old Jul 26, 2005 | 02:35 PM
oange ss's Avatar
i used a 3/8 NPT male to 1/8 NPT female..mine screwed into the end of the fuel rail
Old Jul 26, 2005 | 03:26 PM
SiL3NtXWS6's Avatar
I guess mine is different? In the directions, it specifially calls for this fitting. I do not see any other way to install it without this fitting either.
Old Jul 26, 2005 | 03:33 PM
superchannelkev's Avatar
i used a 3/8NPT as well
Old Jul 26, 2005 | 04:06 PM
oange ss's Avatar
Old Jul 29, 2005 | 12:10 PM
SiL3NtXWS6's Avatar
Just ran into another problem... How do i use my wet kit and a fuel pressure gauge?
Old Jul 29, 2005 | 12:43 PM
oange ss's Avatar
90 degree thru fitting or T off the fuel rail
Old Jul 29, 2005 | 01:35 PM
SiL3NtXWS6's Avatar
I talked to dynotune and they said there's an adapter in the kit and that i actually need a -4an female to 1/8" npt female. I found the fitting i needed, but now i can't find a T or 90 type fitting you speak of that would work. I would need a -4an female, a 1/8th female and a -4an male on the fitting.
Old Jul 31, 2005 | 01:08 PM
SiL3NtXWS6's Avatar
up...
Old Jul 31, 2005 | 09:55 PM
Ferocity02's Avatar
Metco carries a single adapter that is a 4AN to 1/8 NPT couple, female female. Do a search for it in this section. I did mine a little differently. I bought a 1/8" NPT T-fitting, female on all ends, then a 4AN female to 1/8" NPT male adapter. On one end of the T-fitting I put the fuel pressure sender, and on the other I put on a schrader valve for easy fuel system bleeding.
