Clips on injectors harness
Old 07-29-2005, 03:04 AM
Drew778's Avatar
Default Clips on injectors harness
if 2 are missing on the #1 and #3 injectors, could this cause any problems?
We've having a problem with the car cutting out on the top-end, could this be the cause of it?
Old 07-29-2005, 03:49 AM
618HAWK's Avatar
I do not think so. Its purpose it to keep the connector from comming off. Unless the connector has some worn socket-pins and the connector is "REAL" loose you might have a issue. But very unlikley that this is where your problem is.
Old 07-29-2005, 03:55 AM
Drew778's Avatar
It's a friends car:
https://ls1tech.com/forums/generation-iii-internal-engine/357176-what-does-valve-float-feel-like.html
Old 08-02-2005, 06:39 PM
WMSuperSport's Avatar
a sponser told me you dont need em. im missin a couple and no probs...
