Heads/Cam/Nitrous, Injector/Pump Q's
Old Aug 5, 2005 | 11:04 AM
70Stang's Avatar
Default Heads/Cam/Nitrous, Injector/Pump Q's
Combo -
2000 LS1, Stage II heads (flow like 288@600), 224 cam, LTs, NX 125 WET shot.
The car made 416/466 on the 125shot, with NO heads/cam/LTs.
I am expecting to make around 550rwhp with the new setup...I know I need a fuel pump and I have ordered the Racetronix 225 kit.
Do I NEED injectors?? Remember, the nitrous is a wet kit, so fuel pump should take care of that....on motor I should only make 410-430ish....
Old Aug 7, 2005 | 09:02 PM
1ORANGEWS6's Avatar
I have H/C on my car and I have larger stock injector than you do and my duty cycle is at 95% N/A. Now I know that you don't have to worry about injectors with a wet kit but I would find out what your injectors are running on the motor.
