BAD miles per gallon, someone help!
Old Aug 11, 2005 | 04:00 PM
Dustin's Avatar
Default BAD miles per gallon, someone help!
A tank is 16 gallons in the 98-02 F-body. I drive 32 miles to work then 32 miles home. That is 64 miles. I use 6 gallons of gas for a 64 mile drive. That is 168 miles per tank. 168 miles divided by a 16 gallon tank is 10.5 miles per gallon. The number are correct. I have been logging this for two weeks now. How on a pretty much stock car am I getting only 10.5 miles per gallon? I do hit a few traffice lights but the whole is pretty much 60 to 75mph depending on how I feel. The speed doesnt differ between mpg either. Correct me if any of my info is wrong. Mods below:
HP Tuners
NGK TR6s
MSD 8.5s
FMS 42lb injectors
Nitto 555r Extreme Drag Radials
TBB kit
Whisper lid
Whisper ram air
K&N air filter
Ported MAF
SLP smooth bellow
FRA
!EGR
!AIR
!Washer fluid reservoir
!Stock exhaust and y-pipe (running open cats with stock manifolds)
!SAP body kit
!Side molding
Old Aug 11, 2005 | 04:12 PM
BKsFinest's Avatar
Bad 02 sensors, knock sensor... any codes?
Old Aug 11, 2005 | 04:41 PM
Dustin's Avatar
rear 02s deleted, the others are fine according to tuner
Old Aug 11, 2005 | 07:50 PM
3rdgenguy's Avatar
air filter plugged? and what is your A/f ratio
