FI Fuel System Setups...
Old Aug 22, 2005 | 09:00 PM
CAT3's Avatar
Restricted User
MECHAM, I would start to replace the main feed line, stock one is probably your restriction at this point...I mean 700rwhp is pretty good for stock lines!
Old Aug 22, 2005 | 09:39 PM
KissMySSo1's Avatar
i would say it's the feed line also.
Old Aug 22, 2005 | 09:55 PM
MIGHTYMOUSE's Avatar
ok so the stock line can flow 700rw, and a single -8 is twice the area of a stock line.. hmm
Old Aug 22, 2005 | 10:49 PM
qqwqeqwrqwqtq's Avatar
As long as fuel pressure is maintained, and there is no pressure drop from the rails or crossover (which would be very hard to make happen with aftermarket parts), it does not matter if there is a single feed, or if it's "Y'd" before the rails.
Old Aug 23, 2005 | 01:28 AM
2001-WS6's Avatar
If you never want to touch the fuel lines again, run -10 from the filters to the Aeromotive Y-block and split to Dual -8s lines out of the rails and -8 from the rails to the a Weldon regulator with boost reference. Then a simple -6 return line works solving your fuel issues until you need more injetor or more pump.
Rick
Old Aug 23, 2005 | 06:08 AM
Wet 1's Avatar
I don't have the numbers on hand, but it's a good amount more than twice the volume of the stock line.
Old Aug 23, 2005 | 09:20 AM
ls1290's Avatar
Dumb Ass Vette Moderator
I am running the single version with -8an to the first rail, -8an crossover, -8an to regulator, and -6an for the return line.
Keith
Old Aug 23, 2005 | 10:22 AM
longrange4u's Avatar
Wow nice looking setup
Old Aug 23, 2005 | 10:49 AM
NA$TY-TA's Avatar
Originally Posted by ls1290
Keith
Keith off subject i know....,but what valve coves are those??
Kyle
Old Aug 23, 2005 | 11:19 AM
ls1290's Avatar
Kyle
Stock ones with the coil bracket holders and two lines filled in. Basically smoothed them flat Took about 2 hours of work for each using a dremal and jb weld.
Keith
Old Aug 23, 2005 | 11:23 AM
Wet 1's Avatar
Were did you mount the coils and what wires did you use? (sorry to get OT)
Old Aug 23, 2005 | 11:24 AM
  #32
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Mine:
http://babyryan.aboutmybaby.com/view...hoto_id=643475
Old Aug 23, 2005 | 01:11 PM
  #33
NA$TY-TA's Avatar
Keith
Thanks..... im sanding mine down now..... forgot about JB weld tofill the holes.. good idea
Old Aug 23, 2005 | 01:19 PM
  #34
69firebird's Avatar
keith,
Where do the braided lines that go into the valve covers lead to?? Looks like they go to the back and end in a fitting.
Thats a nice setup by the way
Old Aug 23, 2005 | 01:31 PM
  #35
ls1290's Avatar
Originally Posted by 69firebird
keith,
They are part of the new PCV system. That pic does not show the other line going off the battery area( in a C5 ) where it attaches to a vented catch can. Steel braided line looks a little better than crappy rubber hose
Keith
Old Aug 23, 2005 | 03:24 PM
  #36
V6 Bird's Avatar
im doing dual in and then the outlets into a y and into the fuel regulator.
OPtion one looks cooler, flows more(however I dont think either of us will out flow option 2) and lets not forget costs more
A tip here...
Use the Y before the rails inlets, and then take the exit of each rail into the regulator...One on each side and return it out the bottom just like in the first pic link posted. Theres no need for a 2 y's in a system like this.
Old Aug 23, 2005 | 03:30 PM
  #37
V6 Bird's Avatar
I dont think you need to run dual lines up to the rails, you could just run two -8 into a -10 'y' then go up the car and split off again, that should save about 100 worth of hose.
Get the moroso Y block their only about 30 buck each.
ed
Run a single feed from the tank. Split a -10 or so into 2 -8's and go into each rail. Then take the outlet of each rail and go into each side of the regulator and use the bottom for the return.....
Dont sweat the hose man...Go to a local hose supply company here in Dallas Called Midwest Hose Supply off of Stemmons and get your stuff. Once the lines are made from pushlok they will braid it for free to super cheap. I paid $50 bucks for 10 ft of -10an, 5 ft of -8an, and 16 ft of -6an pushlok.
Old Aug 23, 2005 | 03:31 PM
  #38
V6 Bird's Avatar
Rick
Thank you...Someone who knows what the **** is going on here.
Old Aug 23, 2005 | 03:49 PM
  #39
i thought we allready established that a single -8 can flow more than twice what the 700rwhp capable stock lines could?
im just trying to save you guys some money.
Old Aug 23, 2005 | 04:20 PM
  #40
69firebird's Avatar
Dave,
You dont know mike, right or wrong, hes not going to change his view
ed
