Need fuel pump and injector recommendation
Old Aug 30, 2005 | 06:41 PM
manueltarin's Avatar
Default Need fuel pump and injector recommendation
I have a 2000 gmc sierra with a powerdyne supercharger. I want to run the 9psi pulley but don't think stock injectors and pump are enough. Or maybe I am wrong. Anyways, what is a good fuel pump and injectors to buy, how much and where? I think Horsepower will be less than 400, right now I am getting 291 HP @ 5 psi.
Old Aug 30, 2005 | 07:22 PM
oange ss's Avatar
SVO 30 lb injectors, Walbro 255 pump....that will be plenty with a little room to grow
Old Aug 30, 2005 | 10:48 PM
METAL MAN's Avatar
Sorry bro but SVO/ standard injectors don't fit on the trucks. You'll want to get the 8.1L truck injectors (30lbs)or the Marine 8.1L injectors (42lbs). The 30's will be more than enough but if you want to run over 450 I'd just get the marine injectors. One Walbro 255 pump will work fine.
Brett
Old Aug 31, 2005 | 11:48 AM
oange ss's Avatar
i did not know that, i assumed it was the same LS1 setup
