Quick regulator enquiry
Old Sep 20, 2005 | 05:48 AM
GTS346's Avatar
Default Quick regulator enquiry
For my project car I planned on running stock tank to a lift pump, from lift pump to surge tank, from surge tank have a walbro 255LPH pump, was going to run a Vette reg/filter then to engine and short return.
Am I able to set it up this way, but remove the vette reg/filter and replace it with an individual reg and filter and still mount this close to the tank?
Was told if I run an external reg I need it on the end of the rails after all the fuel has passed thru and need to run an In and Outlet on the rails with return running full length of car?
Isn't it possible to run it like the vettes do just with individual reg and filter?
