1 fuel injector not workin? maybe
Old Sep 23, 2005 | 09:41 PM
santiago's Avatar
Default 1 fuel injector not workin? maybe
I took out the injector plug while it was idling and it sounded the same, it didnt run crappy like when i pulled the other plugs. I tested the coil for spark ant it was workin so the only thing I can figure is the injector.
can I buy just one injector. they are ford injectors im guessing 30# but not sure.
and has anybody had the same prob?
Adam
Old Sep 24, 2005 | 04:46 PM
99ss00ws6's Avatar
Adam
Two of my injectors went bad, Just get a digital ohm meter and run a continunity check. You can buy just one injector. I purchased a used set because after I finish breaking my car in I am going to the svo 30#ers. You should be able to tell what injectors you have from the pt #'s.
Old Sep 24, 2005 | 06:36 PM
santiago's Avatar
thanks for the pointers, I checked the part # and they were 30# so I'm jus gonna go ahead and buy one.
