Racetronix Gets It Backwards
Funny thing - I got absolutley NO documentation with my pump
I ended up having to search the wealth of info here to figure out how to install.Maybe they didn't put manuals in with the first batch of pumps for the plastic tank cars
Luckily GMHTP had done a write up on this exact install (same exact car as mine (!) , Blue '94 Z28 A4) and I read the article again before spinning the wrenches. New pump and wiring harness work great.
The F98 and F99-FPA kits have had manuals with them since day one but some dealers forget to include them. The F99-FPA manuals are now placed in the box to prevent this problem. Again, all dealers are aware that the F98 and F99 manuals are available from Racetronix in PDF format simply by e-mailing support@racetronix.com with your purchase information.
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
Thanks. I should have contacted you directly. As usual, I was in a rush and took the first answer and just drove on from there. All's well that ends well, and I must say it's a quality kit and seems to be working very well for me. My alternator, however, has a different harness setup (small, 7mm? bolt in the boot on the back) and I had to run the power wire to the hot lead in the red plastic "cup" above the battery area/near the coolant filler/overflow neck. My battery is relocated to the back, so I could not use some of the parts supplied. But again, it is a good kit and with the aid of the GMHTP article, the install went very smooth.
