Help with ? fuel pressure ? or pinging...
First, I have had bad problems with pinging, in the upper RPMs. I have new OEM plugs, and just added MSD wires. I had the pinging before changing these recently. I have also change the fuel filter. Additionally, I have SEAFOAM' d the vehicle, sucking it through the vacuum line to the booster, and spraying through the throttle body.
I person advised me to check the injectors and fuel pump, for clogging, or impending failure ( I have also treated the fuel system. ) Now, the QUESTION is: If I had a fuel system problem, wouldn' t my O2s read low, on my Predator? With a custom tune, I read a little rich, 940mV. I know the O2s aren' t the most accurate way to ready what' s going on, but, if I had a pump going out, or clogged injectors, wouldn' t my O2s be lower?
Thanks for your input. I had tried searching but didn' t really find something relatable to my question.
P.S. Any good tips, besides the usual ones, for pinging?
https://www.casperselectronics.com/M...Category_Code=
Thanks
Take a look at you injector duty cycles when you are picking up kr. Carbon deposits act like a sponge and soak up fuel that would otherwise be used for combustion. This increases the fueling requirements of the engine and further stresses the injectors. With LTs on the car, the O2s are more inaccurate when trying to determine afr. You probably should take it to a dyno shop and have them hook up a wideband to see what your afr is before determining that it is running rich.
