Should I replace injectors NOW?
Old Nov 6, 2005 | 09:48 PM
BadAssFast's Avatar
Default Should I replace injectors NOW?
We know I have good compression and i'm doing new intake, cam heads next week -- run a wet system (NX 150) ... is 63,000 miles a lot on stock injectors? How can I tell w/o flow testing? Any rule of thumb on proper time to replace them. BTW - I may add a dry second stage and Racetronix in 6 mos at which time i probably would replace them...but I wonder if I shouldn't go ahead and do it?
Old Nov 7, 2005 | 08:06 AM
Matt@HSW's Avatar
Well since you're doing a cam a and heads next week more then likely you'll be/having her tuned, so it makes sense to change them out. Not to mention after the heads/cam you will be or will be very close to maxing out the stock injectors. If you're staying with the wet only shot a set of 32 Lbs should suffice. If there is a chance of adding a dry stage down the road you might want to look into a set of 42 or 60 lbers. I'd also look into the fuel requirements before spraying a heads/cam car.
Matt
