99 Vette Fuel Filter/Reg ?
Old Nov 9, 2005 | 10:43 AM
ROBE's Avatar
Default 99 Vette Fuel Filter/Reg ?
I'm using a 99 corvette fuel filter/reg for a swap I'm doing. What I'm looking for is the quick disconnect fitting used on the filter/reg, possibly with a -6AN fitting so I can run some braided line. I could possibly get them from a salvage yard and use comression fittings for the braided line but I'd rather use the quick disconnects. Street & Performance in Arizona carries what I'm looking for but a single fitting costs almost what the filter/reg cost me. I'm just looking for other options or companies that carry what I'm looking for. Also curious about what others did besides using compression fitings on the filter/reg. Any help would be appreciated.
Thanks,
Robe
Old Nov 13, 2005 | 07:27 AM
69GMC/99LS1's Avatar
Aeroquip makes a disconnect fitting that works nicely, but you're gonna hate to pay for it. 1/4 turn to lock/unlock and it has a poppet valve in there so you don't syphon your gas tank dry. I too used the vette filter regulator, I used Russel fittings that crimp onto the tubes coming off the fpr, than ran -6 hose. I'm using a pre-filter on my setup, my feed line comes off the tank, to the quick disc. , then to the prefilter, then to the pump, and finally to the fpr, then up to the fuel rail.
Like I said, it's pricey, but maybe this will give you some ideas. Luckily, the Navy donated to my cause.
http://apps.esg.aeroquip.com/product...3551,3606,3558
Hope this helps.
-Brandon
