When will 42lb injectors be maxed out?
o Turbos and SCs typically run richer than normally aspirated engines.
o Smaller injectors give better fuel control at idle/low speed.
o To truly be "sequential", injectors should be running at <65% DC, otherwise they're flowing almost all the time at high RPM and might as well be batch fire.
o To count as "42 lb." as installed, obviously fuel pressure has to be the same psi above boost as when flowed.
O I'm not an SC expert, but depending on your other mods, I would guess 10 psi would be good for closer to 700 CHP, suggesting injectors of at least 55 lb./hr.
Hopefully someone with actual experience will now jump in to 'fine-tune' my S.W.A.G...
Hopefully this weekend I will get a chance to run it on the ease program and I will take a look at the duty cycle.
I am also concerned that perhaps my O2 sensors need to be replaced. I was seeing a good A/F ratio. I went to the dyno Friday and saw it was running a bit lean.
Keep it coming, just curious what you guys have seen. . .
Rule of thumb has been if if plan to go around 600 the 42's are perfect but if are going much above to upgrade. I think 60's (motrons?) were the next logical step as they tune easily like the 42's.
Things to check to ensure you are getting the correct injectors:
Fuel pump - pressure idle through wot (steady pressure, no dips and minimal trailing off).
Injectors - if using used injectors, send them to a shop for cleaning / flow matching.
Tune - make sure your fuel trims are all slightly negative, verify wot fuel with a wideband.
Remember that the injector sizing calculators do not take into account a rich tune, clogged injectors, a tired fuel pump, or rich / lean tune.
