E85 injectors?
Old Nov 16, 2005 | 10:22 PM
camrsz's Avatar
Default E85 injectors?
Does anybody know if you have to buy ethenol spacific injectors or just get an injector that is about 1.6 times larger then you would use for gasoline?
Old Nov 18, 2005 | 01:27 AM
Bombguy99z28's Avatar
I would assume you would just have to run large injectors or spike the fuel rail pressure up some. I'm going to be trying this sometime over the next few months, probably put 42lbers in and see how my duty cycle is. Desired afr at wot should be around 7.5-8:1 or so, thats a ton of fuel.
Old Nov 18, 2005 | 09:58 PM
camrsz's Avatar
Thanks thats what im going to try aswell. Let us know how it goes for you.
