help setting up fuel system
This is all you need for the fuel system other than the larger injectors. I recommend the SVO 42lb fuel injectors. Do not install the injectors until you get to wherever you are getting the car tuned at. You can go ahead and install the ATI ProCharger, belt and all, and drive the car part throttle to where you are getting the car tuned at. Do not go wide open throttle! Once at the place where you are getting it tuned, you can swap out the injectors. We have had customer's drive their cars from several states away to get their cars tuned in this manner, it does not cause any problems. Hopefully this helps. Bob
Link for more info
Matt
