empty a fuel tank
Make sure ignition switch is off, remove the cap on the end of the drivers side fuel rail, and remove the schrader valve inside it. Connect a piece of fuel hose, and place the other end in a fuel can,,, then turn on the key and watch it squirt. If you want to make a good hose to connect to it, a #4 AN fitting is the correct size, something like this would work fine:
http://store.summitracing.com/largei...rt=AER-FBM1011
