98 gas tank
Old Jan 26, 2006 | 06:06 AM
Blksilvr's Avatar
Default 98 gas tank
Is there a write up on how to re move a gas tank from a 98 Pontiac TA?
Did a search did not find anything.
Thx
Rik
Old Jan 29, 2006 | 04:33 PM
HellRaiser's Avatar
Should be he same as my 99, just a metal tank. You have to remove the catback exhaust and the heat shields and stuff. Then you have to go in the rear fender well where the gas cap is and remove the bolt that holds the neck into place. After that is loose unbolt the 2 straps that hold up the tank, I think the bolts are a 17mm or something like that. There up there pretty deep but you can get to them easy. Tank should come down after that.
