To return or not to return....
Old Jan 26, 2006 | 11:11 AM
Syxx613's Avatar
Default To return or not to return....
hey all, im in the middle of doing an LS1 swap into my 98 V6 bird and the v6 has the return system, but that year ls1 does not. which should i do? if i get a 97 vette rail i can return it but if not, will i run into any problems with NOT returning it? will i set any codes? im thinking not because the ls1 pcm doesnt use a return anyways. i just need a little help here, thanks! o and does anyone know where i can get new fuel lines for the whole car? thanks!
Old Jan 27, 2006 | 05:03 PM
Syxx613's Avatar
top for me. anyone?
Old Jan 27, 2006 | 05:13 PM
onfire's Avatar
Coal Mining Director
You will not set any codes either way as the ls1 uased a "mini return" from the fileter to the tank. Since you have the lines in place it would be much better to use the vette rails with a dedicated return.....much more stable system and more room to grow hp down the road.
