Please help me with my fuel system
Old Feb 1, 2006 | 08:01 PM
NoGamesLS1's Avatar
Default Please help me with my fuel system
I am building a 393 ls1 with the asa hotcam 226/236 .525 .571 (I have 1.85 rr on the exhaust) and livernois stage 1 ls6 heads. I plan on spraying in the near future. And maybe a bigger cam in a year or so. What size injectors should I run? Will 42lbs be good? Also, what are some of the better in tank fuel pumps?
Thanky you
Steve
Old Feb 1, 2006 | 08:14 PM
rwb's Avatar
rwb
42's should work fine, but put a set of 60's in it so you never have to worry about a fuel shortage. (that sounds wrong) With a set of 60's you won't run lean at high rpm unless you lose a fuel pump.(sounds better)
Old Feb 1, 2006 | 08:45 PM
NoGamesLS1's Avatar
If you are running that big of an injector will you smell fuel? A friend of mine used to be big into 5.0 mustangs and he was saying that when he went with 42lbs his car smelled really bad of gas.
Old Feb 1, 2006 | 10:56 PM
Matt@HSW's Avatar
Are you spraying a wet or dry shot? Take a look at the Racetronix fuel pump kits.
Matt
Old Feb 1, 2006 | 10:59 PM
NoGamesLS1's Avatar
I would be using a wetshot
Old Feb 2, 2006 | 08:05 AM
Matt@HSW's Avatar
You'll be fine with the 42s. If you wanted to go a little smaller you could too.
Matt
Old Feb 2, 2006 | 08:11 AM
GFORCE1320's Avatar
Yea, 42's will work fine.
By Brett Foote | 2026-06-04 05:00:17
