what is needed for a 408?
Old Feb 14, 2006 | 12:17 AM
camarokid94's Avatar
Default what is needed for a 408?
I will be doing a 408 soon. I was wondering what is the min that has to be done to the factor system to keep up?
i have a racetronix pump and hotwire kit.
i will be doing 42lb injectors.
what is the bare min to do.
will be a 408 with ported 205AFRs and a TSP TEXAS giant cam.
thanks guys and gals
not that it matters but it will have a 200 wet TNT shot. but this will get a stand alone fuel system with 105octane sooner or later. i might just run the 150 till i get the stand alone done to paly it safe.
Old Feb 14, 2006 | 11:34 AM
Nasty N8's Avatar
The Nitrous does matter if you are running it now through the fuel sytem. Your Racetronix is only a Walbro 340 pump and is good to about 600rwhp. Depending on what the motor makes (500-550) you have very little head room for the nitrous. Either do the stand alone for the nitrous or do a complete fuel sytem and feed both the motor and nitrous with it. You will require alot more fuel than the single Walbro can supply.
Nate
Old Feb 14, 2006 | 05:40 PM
yeah thas about what i though. probably cheaper to do the stand alone huh.
