Need a 42# table
Old Feb 23, 2006 | 11:00 PM
critter's Avatar
Default Need a 42# table
Does anyone have a table for the 42# Lucas/Dephi injectors?
I am nervous about simply scaling the table as I believe the disk injectors have different response characteristics than the current pintle injectors.
As an aside, I was astounded today when I finally got a log with the 370 inch motor and my 30# SVOs saturated at 4500 at 12.5:1 and it went as lean as 15:1. Luckily nothing broke ...
Old Feb 23, 2006 | 11:17 PM
Moparnos (The SLP Guy)'s Avatar
Flossin' twin turbos
48.83314694 49.13748993 49.43995947 49.74058975 50.03941391 50.33646413 50.63177161 50.92536669 51.21727881 51.50753658 51.79616782 52.08319956 52.36865812 52.65256906 52.93495731 53.21584708 53.49526201
Old Feb 26, 2006 | 08:54 PM
critter's Avatar
Thank you very much, sir!
Old Feb 26, 2006 | 09:09 PM
CamTom12's Avatar
I used that table for mine earlier today... no dice.
Got idle alright, but when I try to give it gas it gets WAY lean and sputters out...
Anything I should go look for?
Old Feb 26, 2006 | 09:48 PM
35th SS's Avatar
was looking for that too.getting ready to swap inj. on the 35th also.thanks.
Old Feb 26, 2006 | 09:56 PM
CamTom12's Avatar
ok, so I went back and took out some of the other stuff that I had done but left the injector table alone.
Looks like that took care of my problem, that injector table looks good from my end!
Old Feb 26, 2006 | 10:29 PM
this is the table for 42's at 43.7 rated pressure if your going lean thats for other reasons with your tune.
Old Feb 28, 2006 | 09:33 AM
GTFORMULA's Avatar
Would I also be able to use this table for my 98 camaro to switch injectors on hptuners
Old Feb 28, 2006 | 11:27 AM
CamTom12's Avatar
I used a slightly different table in the end. If you're going up to SVO 42's, then this table is close enough
Old Feb 28, 2006 | 11:59 AM
Part Number Delphi 01D030B (Lucas old 5208009, Lucas New 621031, Delphi old D3181AA)
Static Flow Rate: 42.29 lb/hr @ 43.5PSI (300kPa) or 320gm/min
==========48.83314694 49.13748993 49.43995947 49.74058975 50.03941391 50.33646413 50.63177161 50.92536669 51.21727881 51.50753658 51.79616782 52.08319956 52.36865812 52.65256906 52.93495731 53.21584708 53.49526201
Old Feb 28, 2006 | 12:02 PM
is that more accurate for ya
Old Feb 28, 2006 | 05:15 PM
GTFORMULA's Avatar
I will be using the Delphi 42# injectors . Where in hp tuners do you change the values?
Old Feb 28, 2006 | 05:28 PM
GTFORMULA's Avatar
ok I think I changed the right one is it under fuel control- flow rate vs. kpa. Then copied and pasted the above values into the slots . Is that correct?
Old Feb 28, 2006 | 09:58 PM
yes sir
Old Feb 28, 2006 | 10:51 PM
CamTom12's Avatar
yup! (even though Moparnos beat me to it, haha)
Old Mar 1, 2006 | 07:44 AM
GTFORMULA's Avatar
And`this should work with the factory fuel pressure right?
Old Mar 1, 2006 | 11:50 AM
yes...
Old Mar 1, 2006 | 12:32 PM
onfire's Avatar
Coal Mining Director
Just curious....if the fuel pressure is stable , why isn't the number constant after it's converted for the proper pressure? Like 48.50? What's the factory constant for factory injectors?
Old Mar 1, 2006 | 02:19 PM
GTFORMULA's Avatar
stock fp is 58 psi . I may be wrong but i think the vacuum of the engine at different times changes the flow just a little.
Old May 25, 2006 | 11:00 PM
TXCAMSS's Avatar
"All Motor 9 Second club member"
Would this table apply to the SVO FMS 42# green tops as well?
