Purge valve question
But do i need to hook the purge valve that is located next to the canister on top of the tank up? If so is it the ECM that controls it? If thats the case i can find the wire from the relay if there is one, or the correct wire that comes out of the Red or Blue ECM connectors to get it working.
Is there anything else that will need to be hooked up for the fuel emissions that i'm missing?
Thanks,
Steve
