Larger injectors and gas mileage
Old Mar 4, 2006 | 05:56 PM
SSDude's Avatar
Default Larger injectors and gas mileage
Will the installation of larger injectors affect gas mileage?
Old Mar 4, 2006 | 08:47 PM
whiteLS1's Avatar
yes it will
Old Mar 4, 2006 | 09:14 PM
catfish1512's Avatar
As long as your not doing anything to bring in more air (bigger cam) you will still use the same amount of fuel.
Old Mar 4, 2006 | 09:16 PM
227Hawk's Avatar
If you adjust the Injector table to your new injectors then no.
Hawk
Old Mar 5, 2006 | 06:17 PM
savethelinoleum's Avatar
If you don't modify your PCM you will run rich with the bigger injectors. There's a LOT of info on injector size if you just search for it, most of it says that unless you've got a heads/cam package you don't need bigger injectors (ie if you're bolt-on only).
