Fuel Pressure Gauge
Old Mar 5, 2006 | 11:30 PM
KAOS's Avatar
Default Fuel Pressure Gauge
ok here is the problem. sometimes the needle on the gauge gets stuck right in the middle like at 45 psi and doesnt move. then if you turn the car off and back on it will go to 62psi and you can see it fluctuate while giving it gas. my father in law said it may be a ground problem but i checked it and it was fine, even rewired it. anything else it could be besides the gauge and sender. also the gauge fogs up on the inside, think that would matter? autometer ultra lite if it matters
Old Mar 6, 2006 | 06:17 PM
White.Lightning's Avatar
Call the manufacturer. Prolly a defective unit. Let us know how you make out.
Andy
Old Nov 9, 2006 | 09:51 PM
crazytrain's Avatar
Has anyone else had this problem? Any suggestions...
Old Nov 9, 2006 | 11:31 PM
02URPITFUL's Avatar
My fuel pressure says it runs at 48psi at idle. But mine never goes up, but it will fluctuate while driving. At WOT it goes down to about 45psi.
