Lost Pressure with Walbro 255
Has anyone else experience this?
kev
Superb, I hope its just the hose in the tank then. I thought the hose I put on had a crazy PSI rating, like well over 100psi. Perhaps one of the hose clips is coming loose. I'll open the hatch and take a look at the weekend.
Thnks for your input.
Sure was a hose clamp problem. thought I had that sucker tight. All reclamped and got over 60psi of pressure on the rails now, used to sit between 57 and 60psi, the guage says about 64psi. The hose is rated at 12 bar, which I guess is about 180psi, so I should be within spec there.
