Which fuel pump??
Old Mar 27, 2006 | 02:32 PM
1ofakindz28's Avatar
Default Hey
Hey everyone, imcurous what do you mean trap door set-up. I ama bout to build my motor and going to be pushing about 500rwhp. I was told to replace the fuel pump. i was going to drop the tank and put a new one in? Does the racve tronix just bolt in? Same with connectors? I also have sv0 30lb injectors will those be big enough or is the duty cycle to small the cam is .600 and 605 with 234-240 durration
Old Mar 27, 2006 | 03:23 PM
Matt@HSW's Avatar
Yup, it's plug and play and won't require you to modify the factory fuel pump bucket.
Matt
Old Mar 28, 2006 | 04:28 PM
Dom's Avatar
Dom
Originally Posted by Matt@HSW
I believe you have it turned around a bit. The rubber hose that comes with the Walbro pumps is the inexpensive one that will break down over time.
Matt
Oh, well excuse my missinformation then. Back when I got my walbro a few years ago everyone recommended replacing that weak stock hose with the high pressure one that comes with the kit.
Old Apr 15, 2006 | 04:49 PM
seriousblack's Avatar
MUST READ- GM HIGH TECH Magazine issue- April 2006. They just did a great tech article on a Racetronix Fuel pump install for 99-02 LS1 install complete w/wiring harness. After I read it, went and purchased kit w/ 32LB Injectors :thumps up:
Old Apr 16, 2006 | 12:02 PM
ashade98's Avatar
They have a kit for 98's too. It's very similar, just designed for the metal tank! I just bought the kit from a board member still sealed in the baggie for $200 shipped. Anyone know where to find more info on the "trap door" method, like measurements or anything? I haven't installed mine yet, and would probably like to go this route. In the GM HTP article, it looks like a major PITA, they say it takes 3 guys to drop the tank, or some BS!
