Where to get Clips on Fuel injectors?
Old Mar 24, 2006 | 12:02 AM
35thls1ss19's Avatar
Default Where to get Clips on Fuel injectors?
You no the little metal clips that go on the plug which goes on the fuel injector.... yea dumb me pulled one off doin my H/c swap and i lost it. ANyone know where to get one? thanks for help
Old Mar 24, 2006 | 01:15 AM
Avengeance's Avatar
I would have to guess that would be a dealer only part. Good luck!
Old Mar 24, 2006 | 06:28 AM
227Hawk's Avatar
I left all mine off, more of a pain in the A** then thier worth.
Hawk
Old Mar 24, 2006 | 07:52 AM
Hodge's Avatar
I think you are looking for:
Fuel Injector Connector p/n 12085491
That is the entire connector. I do not see a listing for just the clip. You might check with one of the forum sponsors. Bet they have something lying around.
Old Mar 24, 2006 | 08:49 AM
Hawk
you havent had a problem with the conector comin off while your driving?
Old Mar 24, 2006 | 08:50 AM
yea i have the connector its just the metal clip that you push in on the connector to take it off the injector... thanks for the help
Old Mar 24, 2006 | 09:37 AM
foff667's Avatar
LS1TECH Sponsor
lol such a simple design but unless you know what your doing its worthless...i remeber trying to do the same thing then realized you just push it in not sure where you can find the clips other then GM probably at 5 bucks a pop lol
Old Mar 24, 2006 | 11:36 AM
lol so you did the same thgin as me! When i relized how they worked i wanted to hit myself lol.... i kept this one of njfboa so all the nj people dotn no i am an idiot but you caught me!
Old Mar 25, 2006 | 03:56 PM
iamsickofitall's Avatar
+1...i think i'll link to this thread over there now
Old Mar 25, 2006 | 06:56 PM
o sure thanks lol
Old Mar 26, 2006 | 08:44 AM
Michael02hawk's Avatar
Do you mean these clips:
http://www.geocities.com/andrew111_98/clip/
Old Mar 26, 2006 | 09:14 AM
xssive's Avatar
No he means the little spring steel wire clips that go on the electrical
connector portion
Old Mar 26, 2006 | 05:52 PM
fletchls1's Avatar
I lost one of mine also..went to gm and it is not listed in their computer. you must buy the actual plug for the injector. it comes with it. its like 30 some bucks too. Luckily when i went to pick the plug up, another guy was in the shop and found one upstairs and just gave to me
Old Mar 27, 2006 | 10:37 PM
ROCNDAV's Avatar
Originally Posted by Michael02hawk
Hey michael, do you the the Gm Pn for the clips in your link?
Old Mar 27, 2006 | 10:42 PM
02WS6Bird's Avatar
Gm does not distribute hte clips separately i found this out the hard way. must buy whole connector which can range form $5-25 depending on parts department
Old Mar 28, 2006 | 05:57 AM
Sorry no, I dont know the part number.
I guess the better solution is to use some aftermarket fuel rilas :-)
btw, what are the real chances of the injector coming out or loose on the stock rail, if the clip is missing? I mean the rails are bolted right down, tightly anyway....
Old Mar 28, 2006 | 06:46 AM
02WS6Bird's Avatar
the connector has a high potential to separate from the injector, it does not hold on any other way. There is way to much vibration and engine torque under pressure to risk putting a hole through a pistion and burning up your cylinder. Think about it!
Just get the connector, unless you can find a junkyard that has an LS1 w/ the wiring in it still near you, but good luck with that.
That metal clip is the only thing locking down your connector, if its gone have you seen how little effort at all can cause it to come off?
Old Mar 30, 2006 | 08:41 PM
lastcall190's Avatar
PMed...
Old Mar 31, 2006 | 11:25 AM
Does this all hold true for the aftermarket fuel rails too?
