fuel pump question???
Old Apr 4, 2006 | 12:12 PM
1redta's Avatar
Default fuel pump question???
I am in the middle of putting a motor in my 96 TA. The engine is as follows: 383, max-effort stock ported heads with T&D offset rockers, solid roller 245i 253e @.640 lift on a 112 lsa, Holley Stealth Ram, 42lb injectors, mono-blade, full exhaust, elec wp, already run 10.70 in a similar car with an auto. My question is will the racetronix 255 kit keep up with this motor? The other guy ran an A1000 but I do not want to sump my tank and the in-tank would be much nicer for the street as well as I would be able to use the stock lines for the most part. If I was to spray it would be later with a sep. fuel system. Thanks Art
Old Apr 4, 2006 | 05:13 PM
Matt@HSW's Avatar
It should be, you can usually squeeze 600 - 650 rwhp out of them.
Matt
Old Apr 5, 2006 | 09:33 AM
mvonada's Avatar
You will be fine.
Old Apr 5, 2006 | 10:42 AM
1redta's Avatar
Default re
Thanks for the replys Art
Old Apr 5, 2006 | 02:29 PM
DR.EVO's Avatar
Check out www.racetronix.com he has a killer in tank set up!
