Injector O-Ring Lube?
Old Apr 7, 2006 | 11:22 AM
JoeMack's Avatar
Default Injector O-Ring Lube?
Installing new injectors and thought I read somewhere to use clean engine oil on the o-rings to aid in installation. Is this true or is there something else recomended? Thanks
Old Apr 7, 2006 | 11:25 AM
oange ss's Avatar
or Vaseline
Old Apr 7, 2006 | 12:18 PM
joecar's Avatar
Clean engine oil or ATF or vaseline (like orange said) or trans gel.
Old Apr 7, 2006 | 12:39 PM
white1's Avatar
12 Second Truck Club
A little used Mobil 1 5w-30 worked fine for me.
Old Apr 7, 2006 | 12:56 PM
GuitsBoy's Avatar
I used a little engine oil.
Old Apr 7, 2006 | 02:49 PM
MrDude_1's Avatar
i usually use ATF or mystery oil.
Old Apr 9, 2006 | 07:52 AM
Cheatin' Chad's Avatar
Petroleum jelly has worked for me in the past as well as clean motor oil.
Old Apr 9, 2006 | 09:51 AM
JoeMack's Avatar
I used motor oil and it seemed to work pretty good. Thanks for the help everyone
Old Apr 9, 2006 | 03:17 PM
tails8's Avatar
Vaseline here...
Tails
Old Apr 9, 2006 | 03:47 PM
xaon's Avatar
I've used vaseline, engine oil, and WD-40... all of em worked about equally. WD-40 was the easiest to use
Old Apr 9, 2006 | 09:01 PM
brad8266's Avatar
Does wd-40 actually stand for something, lol. Maybe I should ask in the tool forum.
Old Apr 9, 2006 | 09:07 PM
oange ss's Avatar
40th try for the correct chemical make up, forgot what the WD stood for
Old Apr 9, 2006 | 09:09 PM
oange ss's Avatar
wd = water displacer
Old Apr 9, 2006 | 10:27 PM
GuitsBoy's Avatar
I saw a discovery special on lubricants where they said it was their 40th try, however I have also heard that it was named such because it displaced 40 time its own weight in water.
Old Apr 10, 2006 | 09:09 AM
MrDude_1's Avatar
water displacement 40... it displaces 40times its something in water...
i forgot what the ratio is about, but it was 40 something in water.... i remember learning that in high school...
Old Apr 10, 2006 | 09:13 AM
GuitsBoy's Avatar
More WD-40 info:
http://en.wikipedia.org/wiki/WD40
Old Apr 10, 2006 | 10:21 PM
anthony m's Avatar
You should use some Astroglide.It helps with getting things in tight places.
Old Apr 11, 2006 | 01:50 AM
joecar's Avatar
I think you don't want to put that where the injectors go... ouch...
Old Apr 22, 2006 | 07:59 PM
z-ya's Avatar
I use whale sperm, there is nothing better.
Old Apr 22, 2006 | 08:03 PM
oange ss's Avatar
do you spit it in a cup first or directly on the o-ring ?
