Fuel pump shutoff switch
Old Apr 9, 2006 | 01:11 PM
Unleashed's Avatar
Default Fuel pump shutoff switch
I want to put a simple switch somewhere on the fuel pump relay so that I can shut it off when I am worried about theft. Has anyone done this? I am not sure which wire I should interrupt or exactly how the switch should be wired. I just don't know what issues I might create if I do this. I have the wiring diagrams and have researched the connections associated with the fuel pump, I would just like to get some advice (do's and don'ts) with this type of mod.
Old Apr 13, 2006 | 09:54 PM
WILWAXU's Avatar
to the top
Old Apr 13, 2006 | 10:42 PM
andereck's Avatar
Hook it up to the ground wire coming off the relay. Put the switch under the driver's seat where you can reach it and nobody will see you operate it, or in the seat side of the console. If its too well hidden and uncomfortable to operate you won't use it and then what's the point.
Old Apr 14, 2006 | 09:53 PM
SmaknaSS's Avatar
That's one way to do it and it will work. but we(my self and friends of mine) like to keep that kind of info away from the web in much the same way people like to keep their smog connect's hidden. I't keeps it harder for thieves to figure out our car's.the good thing is there are manny way's to disable a car. but the bad new's is if some one really want's your car, nothing that I or you can do to keep someone from taking it.
