Injector Leaking...Few O-Ring Questions??
Old Apr 12, 2006 | 05:33 PM
HILL_SS's Avatar
Default Injector Leaking...Few O-Ring Questions??
I have the Racetronix (Delphi) 42LB injectors on the ole SS and the 6th Cylinder Injector is leaking...
My question is when I go to find some O-Rings to replace the bad one...will a stock size O-Ring still fit these???
I figured it would since this injector went into the stock fuel rail and a stock LS6 Intake...
If anyone has any input Id appreciate it...TIA
Old Apr 13, 2006 | 12:56 AM
HILL_SS's Avatar
I guess no one has had any of their aftermarket injectors leak yet...
Old Apr 16, 2006 | 10:39 PM
cantdrv65's Avatar
Post
Either the Ford dealer or Chevy dealer has the O-ring kit. They are all the same. Unfortunately, it slike 70 bucks for the set, and I couldnt find just one. I ended up repairing a torn o-ring. Dont even ask, but it doesnt leak! lol
Old Apr 17, 2006 | 12:34 AM
35th SS's Avatar
just got done swapping mine.#5inj. leak on me the first time Icheck for leaks.had to take the rail completely out of the intake and just replace the oring from my 28s that came out.make sure you push it in all the way and the locks in place and lube it with vaseline or eng. oil.good luck.
