Fuel system for 700 HP?
Old Apr 15, 2006 | 07:28 AM
Public Enemy's Avatar
Default Fuel system for 700 HP?
Hi guyz,
What fuel system to use with a N/A high-revving 408ci engine with solid roller camshaft? it should be pushing around 700-750 crank HP.
thanks
Old Apr 16, 2006 | 07:43 AM
anyone?
Old Apr 16, 2006 | 09:38 AM
markp03's Avatar
you could run duel intank walbro 255 pumps and some 60# injectors...i am not sure if you need to upgrade lines or rails but that should get ya started....
or you could run a walbro 255 intank pump with a inline boost a pump
or a few companies make fuel pumps that are good for around 700 hp fi 800 n/a
Old Apr 16, 2006 | 10:41 AM
yeah im thinking about mototron 60lbs injectors.. but not sure about the lines and rails.. btw, im using stock fuel tank.
any other thoughts?
Old Apr 16, 2006 | 03:35 PM
dame's Avatar
racetronix dual intank setup......very clean, and its P&P
Old Apr 17, 2006 | 01:50 AM
Racetronix's Avatar
LS1TECH Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Available through Lonnies Performance:
http://www.lonniesperformance.com/
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
