Siemens or Delphi injectors?
Old Apr 16, 2006 | 07:40 PM
96 Comp T/A's Avatar
Default Siemens or Delphi injectors?
Hey Gents, I am looking to go big for my next injector upgrade probably 80-85 lb'ers , has anyone had a good or bad result with either of the two listed brands. I see on the Racetronix site that the spray pattern is different between these, one being a pencil beam pattern and the other being a 16 degree cone. Which one do you think the LS1's would like? They are going in to a converted GMPP intake, squirting down into a set of ETP 225's.
Old Apr 17, 2006 | 03:53 PM
Moparnos (The SLP Guy)'s Avatar
Flossin' twin turbos
i never had probs with delphi's and i am also using a gmpp intake
Old Apr 18, 2006 | 08:53 AM
Typhoon#1600's Avatar
The DELPHI's are a good, well-tested unit, still in use today by many people. It is the OEM manufacturer for Holley/Accel. DELPHI actually makes a lot of injectors for many other manufacturers. Siemens/BOSCH make their own stuff. Also a good product. A bit more expensive. I am running the DELPHI 95#ers in my truck with no probs.
Old Apr 18, 2006 | 09:11 AM
Full Throttle's Avatar
The Siemens units are much better quality IMO, the Delphi units work but not as well.
