A1000 Pump mounting
Old Apr 24, 2006 | 07:41 PM
Red95Formula's Avatar
Default A1000 Pump mounting
Where does everyone mount the A1000 pump if you are using one? I am thinking of mounting it where the rear bumer support is supposed to be.
Old Apr 25, 2006 | 12:37 PM
andyws6's Avatar
There is an area just foward of the rearend on the driver's side that you can tuck it away in. It is around where the rear seats are. I will see if I have any pics. I'll post them if I find them but this area worked good for me.
Old Apr 25, 2006 | 12:52 PM
sslow2000's Avatar
i just mounted mine to the bottom of the trunk... gets a lot of weird looks but it works...
Old Apr 25, 2006 | 02:41 PM
Josh@KY-Turbo's Avatar
Is it nessacary to sump the tank to run this pump? If not where are you guys feel lines routed too?
Old Apr 25, 2006 | 05:24 PM
andyws6's Avatar
On my previous set-up, I just used the stock pump to feed the A-1000. At the time I was only running 500 RWHP supercharged but it worked. I currently have the Nasty set-up.
Old Apr 28, 2006 | 08:45 PM
I am going to sump the tank and run new braided line to the motor. I am thinking of mounting the pump where the rear bumper support was.
