Cure for gunk at 7th injector?
Old Apr 29, 2006 | 01:56 AM
Wnts2Go10O's Avatar
Default Cure for gunk at 7th injector?
as i lay in my insomniatic state i come up with an interesting idea and come here. well theres a few people with the issue of a bunch of crap in the corner where cylinder number 7 happens to reside. my idea you ask? it requires a tube cutter, compression fittings, a flairing tool, and a small length of hard line. in essance the "H" fuel rail would turn to an "A" or a weird zero if you wanted to do the front. the reason i say all of this is to not give a place for the dirt to sit and would make cleaning as easy as a good fuel injection cleaner. what do you think?
Old May 1, 2006 | 10:44 AM
Nasty N8's Avatar
Sounds like it could work or get a set of Billet rails and run the hose any way you like.
Nate
