Help with Racetronix fuel pump
Old Apr 30, 2006 | 11:16 AM
mike#9's Avatar
Default Help with Racetronix fuel pump
I have the racetronix setup...with the voltage enhancing harness.
My question is...what fuse should the harness plug in to. It happens to be in the same one that my amp is hooked up to and I keep blowing the fuse and my amp is now toast.
The shop that installed the harness put it on the fuse.
What do you guys think
Old Apr 30, 2006 | 12:49 PM
227Hawk's Avatar
The pump power should be attached to the auxillary power post. This is located on the driver's side fenderwell. The other choice is back of alternator.( fender is easier)
Hawk
