What rail pressure
Old May 2, 2006 | 11:49 AM
Boostaholic's Avatar
Default What rail pressure
Ok on a boost referenced FPR if your running enough boost to make it so boost + base rail pressure > pump max pressure @ volume what happens?
I have two A1000 pumps and they say 45PSI? I know the max PSI must be quite a bit higher than that, because I would think my base rail pressure would be at least 45 so I should see around 70psi rail pressure under full boost.
Old May 2, 2006 | 01:07 PM
Nasty N8's Avatar
They will run alot more PSI than 45 they just rate the flow at that psi. Your pressure reg. will set the fuel pressure.
Nate
