differences in years for fuel system?
im doing a v6 to LS1 swap on my 98 firebird and im using everything from 98 to keep it simple. well the v6 uses a return system and i need a new pump and i want to go returnless. how do i set this up? what pump, regulator, sending unit, and do i need to tap into the feed line to go back to the tank before the filter for the regulator? thanks guys!
For a returnless system you will need a regulator near the tank on the feed line.
Its too bad I trashed so much of my OEM fuel system otherwise I'd give it to you for shipping.
Nate
