Help in INline fuel pump install
Old May 11, 2006 | 07:16 PM
M6WS6's Avatar
Default Help in INline fuel pump install
Where are you mounting your inline fuel pumps? Where are you wiring them? I thought this Walbro kit would have had better instructions, instead it is a replaced instructions, so no help to me. Any suggestions or proven methods?
Old May 16, 2006 | 10:07 AM
SLowETz's Avatar
Above and to the left of the tank on the driver side. Bring 12v power back from the 12v hot post on the driver side in engine bay to a 30 amp relay.
Wire it in line with the stock pump to come on and turn off with the stock pump.
Old May 19, 2006 | 12:33 AM
tweeder's Avatar
I too bought this pump and dewmanshu gave me a link so here it is and hopw it helps.
http://www.magnacharger.com/pdf/manu...SUV1999-02.pdf
Old May 19, 2006 | 12:41 AM
jeremymcclure's Avatar
just make sure you have the pump mounted lower than the lowest part of the gas tank... some pumps dont like to "SUCK" the fluid from the tank they just like to "PUSH" the fluid out. i have seen many people having these problems with inline pumps. unless you are using your stock pump also then you should be fine...
trust me youll be banging your head against the wall if that happens
what have you got in your ride that you need another pump? i have heard the stock pumps being good for at least 500rwhp
