fuel psi regulator
Old May 17, 2006 | 05:58 PM
rorric's Avatar
Default fuel psi regulator
hi my 99 Z turbo project is almost done but I have a question on the fuel rail and regulator @ 8-10 psi with 42 lb injectors, will I need a new aftermarket regulator and can I keep my stok fuel rail
thanks jerred
Old May 17, 2006 | 06:05 PM
Boostaholic's Avatar
You need a boost referenced regulator to do it right, they are not real expensive either.
Old May 17, 2006 | 06:19 PM
rorric's Avatar
Thanks can I pick one up from any of the sponsers on here
Old May 17, 2006 | 08:22 PM
bboyferal's Avatar
Stock rails here with 60# injectors.
Old May 17, 2006 | 08:54 PM
Yes many of the sponsors on here have them, got mine from Thunder but ls1speed has also been helpful in the past.
Old May 18, 2006 | 05:44 PM
rorric's Avatar
I just talked to a guy from thunder and he said I coudent just put a boost referenced regulater on stock rail's with stocks fuel sytem.I toled him it's not all stock. but he said on a LS1 it all hast to be changed.
Old May 18, 2006 | 05:48 PM
wild1100's Avatar
you need to do a fuel pressure return setup which involves a return to the tank and a regulator plus line and fittings
basically run off the shrader valve on the fuel rail to the regulator then the other port on the reg to the tank
Old May 20, 2006 | 05:22 PM
MiaSSmaro98's Avatar
damn all that work.wats the limit on the stock regulator?i mean bboy runs 60lbs inj and make almost 500rwhp i mean thats more then enough for me.
 Michael S. Palmer
Old May 20, 2006 | 05:59 PM
bboyferal's Avatar
I AM NOT running the stock regulator, though...
60#-ers, Walbro pump, and FP regulator... Stock everything else fuel-related though... For the time-being... This winter I'll complete what I started.
Old May 20, 2006 | 06:12 PM
wat fp regulator do u have bboy?did u have to run a line to back exc?also did they have the speedstyle hangout this week?
