Fuel filter between fuel cell and inline pump
Problems with using the wrong filters can include: very noisey pumps, air in the fuel which can affect system performance
, and possible pump damage.Other options for fuel filters are Weldon Pump and Hilborn Fuel Injection.
Andy
Whatever you do don't skimp here as the prefilter is critcal to system performance and durabilty. You can force fuel through a crappy or dirty outlet filter and while it will be harder on the pump you might get by for a while.
If you have a cell, consider removing any foam that may be in there as its known to come apart and block the filter. At the very least pick up some -10 caps and plugs so you can inspect and clean the filter every so often without making a big mess.
