WOT fueling problem?
Old May 21, 2006 | 10:28 AM
Red12secZ28's Avatar
Default WOT fueling problem?
I have a 98 vette with the return style fuel system. I been noticing when I'm logging with efilive that when I do a full gear pull; when I start at 2,500 rpm in 2nd gear and pull it to 6,500rpm full throttle, that the car pulls knock consistantly around 5-5,200 to 6,500. Also I notice a flat fuel curve while logging the o2's. They read about 890-920 mv until they hit 5,000 and start to drop 50-100 mv. But what gets me is that if say I hit full throttle in 2nd and pull from say 4,000 to 6,500 the car shows no signs of knock( which I think is induced because of the sudden fuel pressure drop) and the 02's stay flat at around 900 mv. My injector duty cycle is about 80% up top. Do you guys think if I change My fuel filter I might get away with not have to change a fuel pump.
Old May 21, 2006 | 01:31 PM
MECHAM's Avatar
filter is easier to change than a pump...so start easy and go from there. (but more than likely it might be the pump..
