injector size
Old May 21, 2006 | 11:51 AM
youngrigo's Avatar
Default injector size
one of my injectors in cylinder 5 gets stuck open every now and then and im tired of having to deal with it. so im thinking of just replacing all off them to better ones since im going to be in their. my question is what size are the stock injectors and what size do you guys think i should get? i have absolute no idea if i should even get bigger ones of just get the same size?
Old May 21, 2006 | 04:50 PM
ozws6's Avatar
The stock injector is 28.8 lbs/hr @ 58 psi. If your planning to replace your injectors, the cheapest route is pick up a set of used stock injectors from an 01-02 F-body or 01-04 Vette. If you are planning additional mods down the road, I would invest in a set of larger injectors that will meet whatever your hp goals are.
Old May 23, 2006 | 08:29 AM
youngrigo's Avatar
if i go with fords 30lb injectors do i need to program my computer?
Old May 23, 2006 | 05:06 PM
ozws6's Avatar
I think the Ford 30 lb/hr injectors are rated at 43 psi. They will flow 34.8 lbs/hr @ your stock fuel pressure (58 psi). You will definately need a tune to run anything other than the stock injectors.
