Fuel system for 800 rwhp
Old May 26, 2006 | 04:02 PM
theblur98ss's Avatar
Default Fuel system for 800 rwhp
I'm getting close to finishing my project and I want to make sure my fuel system is up to par. I have a bosch 420L pump with 8an feed and 6an return. I'm planning on doing apx 550 on motor and the other 250 on nitrous. Will this setup be enough? Should I do a bigger pump or run a seperate system for spray? Thanks for ideas and suggestions.
Old May 26, 2006 | 08:21 PM
onfire's Avatar
Coal Mining Director
A 420L is good for roughly 750 engine hp. I'm running two 420's and it holds steady pressure at 700rwhp. Add a second pump for the n2o.
Old May 26, 2006 | 08:45 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I run 2 420L's and have hit 754rwhp.
Old May 26, 2006 | 09:51 PM
Do you just run the pumps in series to each other?
Old May 26, 2006 | 09:54 PM
onfire's Avatar
Series won't add the volume that you need. Parallel is the way. Don't run both pumps at the same time while cruising or it will heat the gas. Have the second pump activate with the n2o. Harris Speed Works can set you up.
Old May 29, 2006 | 03:45 PM
stevensLS1's Avatar
a really good one haha. i wouldnt know.
