I Got A Problem, Need Help!!!!!!!!
Old May 27, 2006 | 05:55 PM
xxxtreme36's Avatar
Default I Got A Problem, Need Help!!!!!!!!
just bought a 94 t/a with 90k on it. decent build, my issue is.... when i go to start it up i have to prime the pump and stall 3-5 time before itll start and stay running. It has a 2yr old inline fuel pump in it. Would this be due to a pump, inline relay, regulator? anyone with similar symtoms got advice?
Old May 27, 2006 | 07:13 PM
Dustin 98TA's Avatar
Prolly a bad regulator. If it wont hold pressure it takes a while to start.
Old May 28, 2006 | 11:01 AM
xxxtreme36's Avatar
so is the only reg the one on the fuel rail itself? cuz after lastnight now the car will fire but wont stay running at all
Old May 30, 2006 | 06:56 PM
03 BUSA's Avatar
Check the filter too. Could also be a bad fuel pump if it won't run at all now.
Old Jun 5, 2006 | 12:19 PM
99Custom's Avatar
Check fuel pump, then regulator....and it's easy to swap out your filter...GET ER DONE
