Help, SVO 36's?
Old May 31, 2006 | 11:51 PM
1ORANGEWS6's Avatar
Default Help, SVO 36's?
I'm getting my car tuned and I was wondering if SVO 36's were to big for my set up. They are already in the car but I was told they were to large for for my setup. I have the 28.8s but they were running at 105% @WOT. Need help quick!
Old Jun 1, 2006 | 12:10 AM
1slowls1's Avatar
cant the tuner retune the injectors to spray at a certain amount anyways?? not sure but i thought so..
Old Jun 1, 2006 | 07:14 AM
227Hawk's Avatar
Those SVO 36s will be fine as long as the IFR is adjusted for them.
Hawk
Old Jun 1, 2006 | 08:28 AM
ZL1Killa's Avatar
you must change the injector flow rate for the injectors. the SVO's will work fine. the injector flow rate table , get it changed for the 36#ers. i can email you an excel sheet so you can go to the tuner and show him what needs to be put in for the numbers, or so you can show him the sheet, and hell he might want to keep it
Old Jun 1, 2006 | 04:17 PM
1ORANGEWS6's Avatar
Thanks for the responses. Killa, I have a spreadsheet from redhardsupra for the injectors if that's the one you were going to send me. If not then send it to me.
