Braided lines, distance from hot spots?
Old Jun 4, 2006 | 10:05 AM
DAPSUPRSLO's Avatar
Default Braided lines, distance from hot spots?
Running the lines up to my motor from the nasty nate fuel setup. Need to know what the minimum safe distance from exhaust pipe, transmissions, and any other heat sources I need to have between the lines and the heat source. At what point does a wrap or heat shielding need to be used? Thanks.
Old Jun 4, 2006 | 11:41 AM
onfire's Avatar
Coal Mining Director
Typically, you need to wrap it where it crosses above the y pipe. Trans, etc isn't a problem.
Old Jun 4, 2006 | 11:45 AM
227Hawk's Avatar
I'm running mine at least 2" from the exhaust and have had no problems.
Any closer and look at wrapping or shielding the lines.
My.02
Hawk
Old Jun 4, 2006 | 12:19 PM
DAPSUPRSLO's Avatar
Thanks guys. What do you suggest for wrap and where do I get it?
Old Jun 4, 2006 | 12:38 PM
227Hawk's Avatar
Look to Summit or>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>Sponsors
Heat wrap
Hawk
Old Jun 4, 2006 | 01:07 PM
DAPSUPRSLO's Avatar
Heat wrap
Hawk
Thanks
