30 lb fuel injectors
Old Jun 12, 2006 | 02:27 PM
2fast2pass's Avatar
Default 30 lb fuel injectors
would it hurt to put these in a stock 98? i have changed them in my cammed cars , but never a stock one before, should this be ok for a car that will pretty much stay stock ?
Old Jun 12, 2006 | 02:34 PM
ZL1Killa's Avatar
it will not hurt at all to put them in, but you will have to tune the car for them.
since it is staying stock why are you going to put them in the car? also, i have all of the spreadsheets that you need to use to recalculate what you must program the computer for
Old Jun 12, 2006 | 03:49 PM
RedWS6 00's Avatar
I have a stock car, well got bolt on's, no heads or cam and running 42#s, all dialed in and running fine. Reason I went large is room for future mods.
If you tune is for 30 lbs it wont be a prolblme at all. The stock is either 28 or 26 in that year. You may even fine you fuel trims will take up the slack, but beswt to tune really.
Thyere is a spread sheet RedHard Supra done for scalling the fuel injector tables.
Injector Scaling
