383 ci
Old Jun 17, 2006 | 07:19 PM
Mike2000Z28's Avatar
Default 383 ci
I'm in the process of putting together a 383 forged shortblock. I plan on running nitrous in the future, are 42# injectors and an in-tank Walbro 225 fuel pump going to be enough?
What setup should I look at, Lucas, Bosch,who?
Is the stock regulator okay for 42# and the walbro?
Do I have to change anything in the return lines?
What else should I look into other then injectors and the fuel pump?
Old Jun 17, 2006 | 08:45 PM
ChevPower's Avatar
Our setup is simular to what your asking. We run 42# Lucas delphi/racetronic.
We put just under 700 hp to the rear tires with a auto tranny and stock system other than a 255 walbro and a booster, O this was on a dry N20 system injector duty cycle was less than 90% we never had problems with the fuel system at that level
Old Jun 17, 2006 | 09:20 PM
Thatz an awesome number you have, what bolt-ons and heads/cam did you use?
I guess I have to start hunting for the injectors and pump.
